Maybe an ongoing thread for what happened to you and how you went last Wedneday night at WSID.
Let's kick it off with our R33GTST.
Usual mods, early stages, 10 psi, standard turbo, R32GTR FMIC, Magic Cat, 3.25" Kakimoto cat back, PFC with BKC, road tune only (no idea how many RWKW) using Tech Edge A/F ratio meter, Group Buy suspension kit, minimum rear camber. New MT radial street tyres fitted (another Group Buy in action). Set at 15 psi on advice from BU5TER (thank you).
Run 1 SOSK did a small wheelspin warm up, "burn out" would be a gross overstatement.
Gentle on the clutch, we have no idea what is in there. Gearbox has zero synchro on 4th and 5th, so granny shift required from 3rd to 4th
Result
60' = 2.461
ET = 14.434
TS = 99.00 mph
Checked the A/F ratios from the first run, everything looks OK
Run 2 SOSK did a slightly larger wheelspin warm up, "burn out" would still be a gross overstatement.
Little harder on the clutch, Still insufficient rpm used on launch, slight bog. Clutch failure on the 3rd to 4th gearchange, roll over the line in neutral.
Result
60' = 2.099
ET = 13.780
TS = 96.53 mph
No more runs and I got to drive it home clutchless, good training for when I get a dog box in the R32GTST. New clutch on the way and we get to fix the gearbox synchros at the same time.
Lessons learnt try for a real burn out next time and never trust an unknown clutch.
:( cheers :(
https://www.sau.com.au/forums/topic/117334-wednesday-night-at-wsid/
good work gary. good to see you are getting matt stuck in. now just coach him to give it some hammering for a nice burnout and a more agressive launch.
We were very concerned about the unknown clutch. So he was more gentle than he will be next time with one that we know and trust.
:( cheers :(
First pass - no gas - 21psi - 1.79 60' - 11.79 @ 121mph
Second Pass - no gas 21psi - 1.92 60' - 11.99 @ 121mph
Third Pass - 75hp gas/18psi/-4 deg - 1.82 60' - 11.66 @ 123mph
Fourth Pass - 75hp gas/21psi/-4 deg - 1.80 60' - clutch slipped in 2nd and start of third - aborted 12.77.
Adrian
I managed only 14.01 @ 100.58 Rev probably only at 2.5k rpm and anymore than that would be wheels spins.
Can someone with similar mods teach me how to launch!!
R33 gtst 3" zorst, FMIC, bleed valve @ 11 psi, stock turbo, SAFC, bigger fuel pump, 18 inch rim with 265 rear tyres at about 35 psi.
I've seen alot ppl with similar mods did mid 13 quite consistantly but i still cant crack 13 :P
Get some 16's or light weight 17's and put some good rubber on them. Those 18's would be slowing your times down alot i would imagine.
I've seen alot ppl with similar mods did mid 13 quite consistantly but i still cant crack 13 >_<
i had same wheels i ran 13.5
i got some 16s droped the tyre press to 18psi then i ran a 12.9
I've seen alot ppl with similar mods did mid 13 quite consistantly but i still cant crack 13 :(
Drop your tyre pressure using street tyres I dropped the tyre pressure from 25psi down to 16psi and picked up 3 tenths going from 13.6 to 13.3
Why do you bother trying to change gears into 3rd? 2nd will give you more than sufficient wheel speed to heat they tyres quickly without the extra load. If you want to do burnouts in 3rd, just start there.
Adrian
i think he meant shifting to 3rd down the quarter after having done a second gear burnout. implying a cosimic link between 2nd gear burnouts, and missing 3rd gear on track.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
