http://nissanking.cjb.net
Car is for sale!! Easy 10s. Does 11.5 @ 124mph street trim.
323rwkw. RB30ET. Lotsa work
Currently defected and doesn't intend on getting the Defect off. Put the Rb30 back where it belongs in the R31 and buy the on @ http://nissanking.cjb.net for $12,000!!!!
ONLY 12G's! For a FULL CAR! no expense spared on this baby!
12G for everything except stereo!
You'd be stupid not to buy it!
PM me and I can get you some contact details if you are interested!
HI Fast 31, RB30 bottom end, JE forged pistons and Carillo conrods, Nismo bearings, o'ringed block with RB26 top end, 264 degree camshafts, adj camshaft pulleys, ported head with matched manifolds, valve springs, 6 into 1 exhaust manifold, Garrett GT3040 turbo, Progate wastegate, Trust 600X300X115 intercooler, TiAL BOV, Apexi Power FC, PWR radiator, 3.5" exhaust, alloy pulleys, enlarged sump, OS Giken twin plate clutch and flywheel.
Has 484 rwhp at 1.2 bar and cost $15K with a mixture of new and used parts. Bottom end will support 750 bhp and engine could easily make more max power, but would sacrifice driveability and throttle response.
Hope that helps
Yea you are hearing right. 11 second quarters (any day of week), 323rwkw, 12k. DEFECTED though.
Ideal for a conversion, R31 or VL, gemini even. It's currently in a MR30 skyline.
If you could get back to me DaBigBolf asap that'd be good If you might know a buyer so I can get hold of the owner and maybe organise something.
Car is in adelaide.
Yea it was in ZOOM a while back.
Time isn't important when you're gonna hav 300+ rwkw!
you think 190 is good fun Nismoid!!!! Drive this thing!
Snaps sideways in 5th. Has all the torque of the standard Rb30 too.
Make him an offer at [email protected]
He's desperate as to sell it!
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
    • Not yet quite as bad as what we've seen a Jim Berry clutch do in an R32 GTR though when it decided to cut a chassis rail in half... Still very very gnarly and a great reason to avoid.
