hello
i am Garry is building me a RB30 bottom end.....then i am putting it together here in canada, we have no experience in tuning RB30, so i would liek u guys help !!
what sorta thing should i look out for ?
what's the difference in tuning compare to RB26 ?
what computer is the best for tuning RB30 ?
what sorta things should we look out for when putting it together with rb26 head, i think we got the basic RB30-26 swap down..but there might be little details that we missed
the engine is going to sit taller, will it clear the hood, i know with rb26 and my t78 turbo it almost hits the hood, will i have even a bigger problem with this issue ?
anything other rb26/30 to BNR32 info would be a great help to us !!
thanks again !
https://www.sau.com.au/forums/topic/117393-what-should-i-tune-rb30det-with/
if it was me (which it's not)
apexi powerfc
then if that wasn't available
autronic or motec
but that all depends on what tuners are in your area, whats the point of a moetc if no one locally can tune it ?
any decent ecu will work as good as any it all depends on the tuner.
you can have the best of the best motec ecu, but it will be no better then the power fc or what ever if you dont have anyone that knows how to use it to its full potential.
if i was you find a really good local tuner and use what ever they recommend.
hi
thanks for everyone's replay
i understand that a good tuner beats a good computer !
and i also understand that not every computer works good with every engine set up
so my question is what computer works the best with RB30/26 with single turbo and no MAF
thanks ...
but thanks everyone for replying it really helped alot !
It sounds like your building a bit of an animal and cost comes second.
If you want the best, get a Motec ecu that is suitable for your engine.
http://www.motec.com/
Sure you pay a little more for them, but you are getting the best, used in all kinds of world motorsport engines.
what ecu's can your tuner tune?
basicly my tuner said, they do not reccomend Power FC......and told me to go for Raytec..but i called tomei and they said, since the Raytec is still very new, tuning RB30 with Raytec is not recomened, i have HKS f-con V-pro right now. but no one can tune it !! :dry:
motec is just too expensive and same as Haltec..
help
your tuner does not recommend powerfc....is he an auto mechanic, or a mower mechanic by any chance?? (personal joke, mate of mine is a mower mech and doesnt like powerfcs, works as a mechanic now. haha thought there might be someone else like him around canadia.) didnt mean to be an insult, my apologies.
Powerfc has got to be one of the cheapest, and easiest a/m computers to use. Its excellent value, and im sure almost everyone on here would agree with that.
Edited by r33_racer
Power Fc is good for your average modified street car, good for cold starts and cruise etc, not the choice for a race car which it sounds like you are building, thats why most people on this forum use Power FC. Only a handful have race cars, mainly street cars. I have used Power FC, Microtech, Haltech, EMS in customers cars, different applications for each one but all have there pros & cons. Apexi D-Jetro may be the go as it uses MAP sensors over airflow meters but is a shit too tune. I am building a similar engine, RB30/26, HKS T51R etc and am definately going to run an Autronic ECU. Much more flexibility for tuner and gives you the ability to trim individual injectors to get afr's perfect in each cylinder with the aid of EGT's. Its a set and forget deal. This is the heart of the operation, rather spend a few extra dollars here than risk the engine. Youl find that alot of the time on this forum people will advise on the cheapest rather than what works better, alot are only speaking from there own experience as they have ony owned a car with the one ECU or boost controller, ie $22 bleed valves etc. You get what you pay for. In the end your tuner is the person you should listen too. best of luck.
Edited by BezerkR32
Well ill know soon enough, we will be using powerfc pro in the 25/30 in a few weeks when it gets tuned. So i guess that will tell the story.
He also mentioned that motec and haltec are too exxy for him, how is an autronic compared to say a motec in price? I thought autronic were not too far off a motec?
Edited by r33_racer
ive used EMS and microtec i would recommend both for the 26/30, if you where in oz i would say go for the microtec because with my experiance there is more people who know how to tune them well compared to EMS. they are both well priced (around $1500au)
i dont know alot about powerfc but the tuners i know dont recommend them so i didnt use it.
but all these ecu's are useless if your tuner cant use them, so i say use what he recommends or find a tuner who can tune microtec(or whatever)
They are not cheap but are getting more computer for your dollar. Have to compare apples with apples.
But if he is worried about price of Haltech, it might be too expensive.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
