  • Replies 65
yeh i had a drive in one they go alright once you hit vtecbut yeh nothing compared to the gtst.....all my mates are obcessed with integras but yeh they arnt that good. they are pritty good for a economical car that still goes alright
I find the integra runs well on the twisties. Not a drag car.
Jon
ahh k yeh the vtirs do handle nicely, only reason i bought it up is ive looked at alot of ppls posts and no one really talks about them and im not sure why. yeh theyr arnt really good for dragging but they are good economically and love the high revs as well!
A GTS-t has a turbo. It takes relatively little effort to dial in more power, compared to a Honda NA engine. Do non GT-R Skylines have "street credential"?
And the reason why no-one talks about them here could possibly be because this isn't a Honda forum. We don't talk about 1920's Packards, De Loreans nor Ascari KZ1's here either.
If there is a vs thread, everyone would tend to go for the top-spec Type-R instead of the silver medalist.
yeh i think they will be better on petrol....would it go as hard as the gtst or not? which one would u prefer?
If you already knew, then why did you ask?
And you're asking on a Skyline forum whether people would prefer a GTS-t over a Honda? Were you expecting an fair and balanced response?
Like scathing said this is the last place people will be raving about hondas if you want more info should check out hondas forums. Also you cant compare a NA against a turbo, cause turbo owns hands down simple. If you want an NA car thats quick, rev high and economical go for the vtir. But if you want something faster and very keen to modify it further to gain more hp then get the gtst. Beacause there are limitation to hondas as they will cost heaps to produce more power (eg turbo charging it).
Edited by JUNR34
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
    • There is an ABS pump and a few solenoids. You could trigger the front/rear solenoids with a pressure bleeder attached with a Consult 2.
