Well finnally after 4 months I finnally have a new set of mags. For those who dont know two were bent in an accident, and had to be replaced. So I went on a mission to try to find two of the same I had, with no luck, so I had to make a choice, and couldnt find anything I really liked and these were the closest and available so just went with them.
The dish is about 75mm deep, which at first I wasnt a huge fan of, but now after seeing them on the beast I am starting more and more to like them.
And here is the result:
post-7853-1147408430.jpg post-7853-1147408447.jpg post-7853-1147408457.jpg post-7853-1147408483.jpg post-7853-1147408500.jpg post-7853-1147408511.jpg
https://www.sau.com.au/forums/topic/117507-new-mags/
  • Replies 75
Posted Images
The mighty koya's, are they? nice looking wheel, love the smokey centre with machined lip look. thats what i went for. mine looked a lot darker in the shop than they do in sunlight though...
Little bit of dish on a wagon goes alright, hey.
yep got dish too. got staggered dish?
and just quietly, what size tyres are you running on those? ive got 225s and 245s... just fit but may cause issues when i save up for one of SK's susp. kits.
Edited by qikstagea
https://www.sau.com.au/forums/topic/117507-new-mags/#findComment-2161574
Nope, no staggered dish, but yeah yours are nice too!
Also looking at having the spokes colour match painted so that they are the same colour silver as the rest of the car, just a little bit darker would've been nice, but meh, they look a crap load better than the 4 stocker skyline wheels which were on it!
https://www.sau.com.au/forums/topic/117507-new-mags/#findComment-2161646
Im not sure thats wise....... being 4wd you should have same size tyres all round on the 4 wheels.
Thats from info Ive read around these pages
so i hear! but the problem was 245s dont fit that well at the front of a stagea... so i had two 18in kumho ectsa supras to sell, and had to pick up a pair of 225s to fit.
its not like anyof the tyres break traction, or ive got 2 way lsds or anything so i figure just this once... looks super tough from the rear.
https://www.sau.com.au/forums/topic/117507-new-mags/#findComment-2162176
yeah I hear ya..... Im running 17s R34 GTT rims, 235's all round.
Im sure its the 4wd system that gets screwed over time - if ya start having 4wd issues (such as light coming on, or error codes etc) you know what it is!! lol
Not trying to scare ya or anything like that, just passing on info.
for example, madaz here in SA had a space saver rim on up front for a little while, cost him 4grand+ in repairs at the end of the day to his R32 GTS-4.
https://www.sau.com.au/forums/topic/117507-new-mags/#findComment-2162196
I agree with tangles. it's not traction loss you have to be concerned about,but rather the speed difference the transfer case has to cope with. different rolling diameters on each end of an awd car like ours will put extra load on the transfer as it'll be compensating for the speed difference at each axle whenever the car is moving,not just around corners. it'll run hotter,and may eventually sieze on you.
I've seen landcruisers blow tansfers from doing freeway driving with worn tyres on the rear,and newies up front...so it's entirely possible that you may suffer the same fate in the long run if you run staggered sizes...
Justin...
Edited by fergo308
https://www.sau.com.au/forums/topic/117507-new-mags/#findComment-2162249
rolling diameter diff is about 0.8mm, so i figure it'll be ok as a "just this once" thing. unless someone wants to buy a pair of 245 ecstas lol
but anyway back to the topic at hand -
nice rims cy. anything beats r33 stockers. cept pursuit rims.
https://www.sau.com.au/forums/topic/117507-new-mags/#findComment-2162265
LOL she'll be right!!
yeah, in no way shape or form am I trying to scare you, just looking out for you my dear friend! thats what it is all about, passing on info to fellow Stagea owners.
can you get 235's in 18's or 19's (can in 17's thats for sure)?
But I agree with you, 245's would look awesome at the rear on the Stagea. Nice.
on topic : NICE RIMS Cy!
https://www.sau.com.au/forums/topic/117507-new-mags/#findComment-2162274
dont know the diff between Stagea and Subaru 4WD systems. My tyre supplier inadvertantly put 2o5 on the back and 225 on the front. Subaru Aust., not a dealer went ape. Result , no cost tyre change.
Something about diff wind up.
https://www.sau.com.au/forums/topic/117507-new-mags/#findComment-2162523
with all awd/4wd systems, the wheels are obviously meant to be rotating at the same speeds, front and back. its not the WIDTH, its the diameter. different width tyres just happen to have different rolling diameter tyres.
If you have a higher rolling diameter, your tyre doesnt need to spin as fast to go the same speed. So obviously if it differs front and back, you rear wheels will be spinning at a higher or lower speed than the front, even though your gearbox is trying to spin them at the same speed. this difference wears out you front/rear clutch packs, becuase obviously if there is a difference, there will be a slippage somewhere to make up for it. my tyres are different widths, but the diameter is pearly spot on, so unless i drive a million k's its not going to be a big issue. i hope...
https://www.sau.com.au/forums/topic/117507-new-mags/#findComment-2162691
Woot! Koya's! One of my managers at work has these on his 32 $ door.. always wanted to see em on a Stagea
Chris! Your car looks hot with those wheels, so does Terminal's!
I might be biased tho, because I love most mesh-style wheels, and I also LOVE dish!
Cyrus, the car looks good with those wheels too. Dish is tops. Good choice.
https://www.sau.com.au/forums/topic/117507-new-mags/#findComment-2163232
Hmmm yeah I suppose so... Still - I love Zenetti Kayotics
https://www.sau.com.au/forums/topic/117507-new-mags/#findComment-2163534
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
    • Ahh. Well the block damage is a problem, you really need to run a tap or thread chaser through it to see if the threads can be saved, but any chips are likely to be bottom end bound which is bad. Earls seem to have what you need if you want to stick with mounting direct on the block: https://rceperformance.com.au/parts/earls-straight-adapter-1-8-npt-male-to-1-8-bspt-female.html, but as I said above I'd recommend remote mounting the sender
    • I'm not quite understanding or I'm missing steps here, (I appreciate people are trying to inform my brain but I am of the dumb, especially today) - All I want to do is mount the male BSPT of the OEM sender into the system somewhere without it snapping the adapter via vibration. The Nissan sender has a male 1/8 BSPT output. The block has a (very destroyed) 1/8 NPT input. I'm not really sure how a lathe assists with that, and also don't know anybody with a lathe, nor specifically what I would want to buy. I'm not really sure how adding additional adapters creates a better, more leak proof resilient seal here.
