  • Replies 80
Posted Images
BB your a unit for sure :-)
i have a Trulli kart ( made by swiss hutless ) with 4 wheel brakes and a biland engine 2 cylinder 4 stroke should suit a big unit!
failing that we have a 63 hp wankle kart engine that is sure to get your palms sweaty and a fair old clenching of butt cheeks happening! You have never accelerated until you get in this thing it is truely frighting, even compared to a super kart which is a lot of gear changing this thing just keep pushing and pushing
i dont think so, superkarts are ususally used on full circuits not on small kart tracks
Sorry i should have phrased that better. What i meant was, If you got a superkart.. Where can you use it and what do you need to use it?
Would you be allowed to use it at track days with cars?
Im assuming it would be too dangerous because the cars wouldnt be able to see you properly
i think your crazy for even asking, please omit yourself to the nut house right away!!
*no offence intended
lol, nice trulli kart with 4wheel brakes and 4 stroke sounds like my GTR! wankel kart would be right up my alley. 63hp is pretty out there. I have breifly drive a superkart once but not in real anger and even still it was pretty nuts, takes a bit of getting used to to drive fast.
but yeah I just want something not too radical that I can still fit into and compete and hopefully not get too badly spanked by 35kg 12 year olds... at least in the post race punch up I'll be kicking serious ass. I've got nothing against fighting a 12 year old. as long as I don't get hurt doing it...
hey guys just thought i would post this up me and my sister had a couple of go carts and then we brought a big trailer with two other go Carts in it. The two in the trailer have never even been taken out her and her husband are separating so they want to sell the trailer and carts the previous owner used them 2 times if im correct so there imac! if you are interested in them im in chelsea heights melbourne and you can come look at them just pm me ps. i have 4 go carts the other two are in my garage and are very very quick track go carts
Yer mate sounds like this would be the kart for you.
little pic of the Biland world tile i raced in Dubai back in dec 2006
i'll have a ready to race rotax restricted kart for sale at the end of the month if anyone cares.....
http://www.sabaar.com/SingleView.aspx?ImgP...05_14092008.JPG
i'll even put a new nose cone on it.....it melted when i was giving someone in front of me a love tap (on their exhaust).
I've had a win...a second and a third so it's a competitive setup.
pm me if you're keen.
the aerodynamic front bumper must work....i just won yesterday at oran park. still for sale if anyone cares.
Edited by tk80
hey guys
i was just wondering what the best cheap go kart is?
see i am only 15 and thinking of joining a team but i need a kart
i probly will only have 1000 dollars so it would be good to know wats around
i am about 6ft and 65Kg
thnx
you wont get much for 1000 these days. and if you do, i doubt that come next year you'd be able to use it on the track (new rules mean you have to have a clutch) no more push starting karts.
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
