Joe your lucky you never lowered your car - because your place is absolute murder for lowered cars took me about 15mins of very slow driving to get down that ramp of yours in the Line!!
But i used to work in this place that had a highrise underground carpark and i was only privledged to bring my car in if i had to work til 6pm. I hated that job - but anyway on the way down i used to set off every alarm i could in the ZX (plus ive left black marks in that carpark for them to remember me by) hin the hope that their batteries would be flat when they left - did i mention i hated that job haha!!
Dont take the line into highrise carparks often as i find that the ramps constantly scrape my kit because its lowered aghh! I did once when i had job interview - and never again because every ramp was *sccccraapeee*
  • Replies 46
Who said I never lowered the car... well you are right I didn't lower the car but my car already been Lowered... but not as low as your or Angel's car.
after taking out my struts I found out that my springs and shockies are not stock... they are some jap after market.
yeah I know my place is very very bad for any lowered car!
even my mate's VX SS commie touches his exhaust on that ramp... :D
hahaha speaking of highrise building car parks... under cover car park at bank west is shocking when I drive my car the exhaust is sooo loud due to echo factor sets off the all the alarm of BMW, Firrararary, Jags.... you name it I set off their alram... heheh.
I got told by sercurity guard to slow down... he think I speed through the car park. :) come on I dont want to hit any of the cars in there ;)
Originally posted by Pva_Glue
ok let me get this straight...
3 people in your family
and there are 5 cars plus go kart...
hhmmmm.... DAMM
Our place is worse, 4 people, 9 cars..
2x 1927 pontiacs in bits waiting to be restored
austin 7 in same state
my 4wd tx3 which is a shell on its side in a rotisarie
old ladys falcon
sisters camry
my rex
and in the driveway dads van and my satria for work..
we need a bigger garage, we've run out space in this one
Originally posted by Nizmo
why mechanics hate my car - Ken n Paul i present to u a challenge hahah ........
Not a problem.
Don't forget I have owned a couple with two more cams , one more turbo and a LOT less room to work under the bonnet.
Cheers
spastic hands
Ken
Aussie delivered - yes it is which gave me a shock when i found out because it had to have gone up to hong kong first then come back down here in 95. Been with Ash Farlay for all of its lifespan til it came into my evil hands in 2000.
In really good nick.
didnt happen to go up my street yesterday arvo did ya? haha mum was painting the front lounge and i get "Lauren, Lauren come here quick before ya miss it" but i was too late - apparently a white skyline was doing a slow cruise of the our street and since skylines are a extremely rare sight around here - she reckons it was somebody looking for my car haha.
my cars around - its usually parked down the side - or quite often im out. I dont exactly spend much time "cruising" around high wycombe haha you'll often see the car parked outside the liqour shop picking up something haha
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
