What happens if im test driving n the screw falls off in the middle of it??
hehehe
Do u start off with the Screw all the way Out??? i can't remember where it was Pre_Set when i first got it.. so yeh
Cheers
Edited by Black_CSR
  • Replies 55
wouldn't have to change the bov, unless it starts leaking when you get on boost. the stock bov is designed to leak at all times. it has a hole in it to do so. this leaking also helps it hold higher boost as the leaking air pushes down on the top of it to keep it closed. i blocked mine up and it started leaking boost so i unblocked and it doesn't spike. but going to an aftermarket bov will stop it leaking any boost and make it spool up a touch quicker. (its like trying to fill a bucket with a cup with a hole in it. plug up the hole and you will fill the bucket quicker).
you would need an aftermarket ecu to get rid of boost cut. and remember that 14psi on a high flow will give more power than 14psi on stock turbo.
Edited by mad082
Thanks mate, exactly what I needed to know.
Well at the moment.. i'm running 12 Psi.. n i'm not getting any Fuel Cut for some reason.. so i'm not sure if i have a Stock Ecu n it has a Rev Limiter on it as well...
I remember when i did my first Test Run when the Boost Controller started working.. it went upto 15 psi.. but didn't cut out.. but i didn't give it stick till redline.. just suprised it went up that high.. n did Pop when i changed gear..
What if i keep it on 12.. n get FMIC.. will that b ok???
Oh yeh Evil_weevil.. u going to Antilag Cruise this weekend??? if u r u could sort my boost problem when i c ya hehe
-SeSaR
Edited by Black_CSR
depends on mods. it is based off air flow, not boost pressure. i was running 13psi with stock dump and cat with not boost cut. the day i put on the dump and cat boost cut was kicking in at 1/4 throttle so i had to wind the boost down.
So Mad082..
As long as I don't get any Boost Cut... it should b ok to Run??
I have a HKS Filter n Zorst 2 1/2 wif Cat n High Flow Muffler.. was driving tonite n was cruising along in the freeway in 5th doing about 90... so i put it in 3rd n give it some stick n c how it go..
It went Hard Alright... but the Boost went upto 13-14 psi.. i'm guessin the Cold night gave it extra PSI
didn't cut out though.. kept going hard.. then had a played around wif this SS... didn't Cut out... Caned it up 2 about 4th then slowed down was worried it mite POP..
-SeSaR
Edited by Black_CSR
yeah should be cool. just have to watch out that it doesn't do it when the engine is cold, but you shouldn't be driving it hard when the engine is still cold. when i have the boost at about 13psi i get boost cut until the pipes heat up. the engine can come nearly up to temp and if i give it a quick boot in 3rd it will start to rev up then cut. it will only do it once or twice, then the cooler and piping comes up to temp and it won't do it again.
it only did it in the morning on the way to work... and on the way to the dyno run, so i had to wind the boost down which i was a bit annoyed about cause i took it for a spin the night before to see if it was going to do it and it didn't.
Sounds Good.. well i put it Back on the way it was before.. which is connect it to the Stock Selonoid.. in which it's suppose to Run Stock Boost n gave it a quick run n it went only up 6.5psi n won't get any higher.. where it used 2 b 8psi.. so that kinda annoyed me..
but anyway i'll put it back on n c how it runs for the Cruise on Sat Nite..
SeSaR
This is getting f*kkin rediculous
You know what is fcukin ridiculous, people like you who think everyone knows how to use the search function from the word go. fcukin ridiculous. Were you born a dickhead or do you work really hard at being one. Grow up Kris.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
