Guys
Ive organised for a few people to go down the night before the trackday and stay at Wakefield Park to avoid having to drive for ages early morning (i hate getting up early) just to make it intime for scrutineering
Here are the details.....
Leaving Sydney on Saturday the 1st of July at 3pm (so please aim to arrive no later than 245pm as we cant wait for latecomers) from the Tooronga Tce Carpark in Beverly Hills (next to the train station) and head for Wakefield Park
Arrive at Wakefield and check into rooms by 530pm, rest of the day is free for whatever, Goulburn is very close and will be the spot for dinner
Ive been told the gates at Wakefield are locked at 530pm, and to go in and out you need a key, the key is a $20 CASH deposit that you get back when leaving on the Sunday afternoon. It is not essential for all, just get one if you plan to go out at night and need to get back in
The cars will be safe while we are there. They can be stored in pit area (most people will probably do this), the spectator carpark, a pit garage ($50 each) or next to the cabins where we will be sleeping
Ive also been advised there is breakfast included if the wakefield guys arent overwhelmed on that morning - so be extra nice to them :D . I personally will be having breakfast in Goulburn and using that as warmup for the cars is a good idea.
So there are some who are already paid, to be on the list you have to pay, no paying on the day, payments only in advance as thats how Wakefield work. Payment will be $50 each person, and the rooms have 2 beds in each room - so choose who you want in your room if you want, not that it really matters
To be on the list, simply deposit $50 into this account and put your full SAU username and "accom" in the box so we know what its for. e.g. "N1GTR accom" etc
Ok then. It's time to get depositing.
The Skylines Australia bank account details are as follows:
Bank - NAB
Branch - Marrickville
Account name - Skylines Australia NSW
BSB - 082 356
Account number - 546 393 766
You will not be on the list until i have confirmed the payment, payments can be accepted until the 29th of June so theres plenty of time to make sure you are confirmed
Paid/confirmed
N1GTR
dOOdz
nath95
mr 32
Liz
DIF
R33DEVIAT
Primordial x2
Sl!m
Godzl1975 x 2
Impact_blue
Bunta
lingeringsoul
Jon Bates x2 (Primordials mates)
satanic x 3
TO4GTR
Here is a map of the meeting point for the day - its close to the Motorway, and has enough parking
https://www.sau.com.au/forums/topic/118391-trackday-accomodation/
  • Replies 82
now that is a top idea. it's such a bitch if you try and drive down there the morning of a trackday, then straight back in the arvo. this way you can arrive at the track ready to drive, not ready for a nap.
cheap too. trust me people it's well worth it.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
