i was asked why my car is so special to me and i answered accordingly, so i wouldnt see how it effects ppl.
They didn't ask why your car is special to you, they asked what make's it special compared to the hundreds of other r33s you see on the road.
  • Replies 108
Posted Images
thanks heaps mate
now thats an idea, i might make a custom design in photoshop or something and put it on the car, if not ill peel it back and try something else...thanks for the idea.. im definitly gonna try make a design tomorrow..thanks mate much appreciated
put up pics once ur done.... :dry:
ur ideas 4 the kit were great, n i wud notice this car to be different from the 100s of 33 that i see......n its a very neat example of a 33 aswell..... >_<
Thanks for your kind words mate,
i will definitly post up some HI RES shots once the weather clears up and i put the sticker on the back..hopefully this wkend coming.
the comment from dan22 should say enough mate, if other members are saying it stands out then that puts a smile on my face..Its different because most r33's all use the same few kits, the 400r and the gtr copy. i went and purchased 3 different panels from 3 different companies. If this is the same as every other r33 out there post some pics of something thats street driven and different and i dont mean this in a smart ass way, i just wanna c what others think would catch ur eye
ey i think u should all leave mr_crust alone (all over a sticker ppppfffffffttttt). He should be able to put a sticker on his car without having to pay thousands to a mechanic first. I think its great he did most of the work on his car himself, "if u can do the job urself, y pay some 1 else to do it"
no one said he cant put a sticker on....
they're saying, why put a sticker on for a certain workshop, when you're car has nothing to do with them.
What makes mine so special you ask? Well the fact the i worked my ass of to save enough money to purchase a REAL jap sports car without any loans, like most guys my age (21yo),and then spend in excess of 10k in the first few months of owning on mods, so its my pride and joy so thats why its so special.
On top of that no real workshops have touched my car, all installs have been done myself or family, which is a top accomplishment for me and has saved me thousands...
im gonna get a custom made sticker it seems.
100% get a custom sticker, if you do all the work yourself then wack somethign on that represents that. I reckon that would be ace plus why represent a workshop when they have done no work ;)
This thread has turned into a bit of a cat fight now.
Mr crust - your car is sweet
Thread closed.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
