Apexi Power Fc And Transbrake
Guys,
Im considering converting my GTR to 2WD car and was wondering if the Power FC has an input that allows the transbrake to trigger the power FC to limit the revs to a pre-set rpm.
If anyone knows the if it can be done I would appreciate the help
Nathan
Ive already got the GTR and done alot of work to get it read for the engine etc. Im just tossing around the idea just want to know if it can be done.
Not interested in people telling me I am wrong in doing it
nathan
didnt exactly mean im telling you your wrong for doin it.. just curious as to why..
anything can be done just comes down to money.. as far as i know power fc does actualy have a stationary rev limit feature how ever you need the proper software to accesss it (just goin by wat ive been told.. so theres a 50/50 chance im wrong)
also i'd imagine setup for drag.. so 4wd would be an advantage i'd imagine.. wat times are you looking at running?
nice target.. i wouldnt really worry to much about goin to a setup with transbrake and rwd... many many people have done so using 4wd.. weather it be using slicks or street tyres just learn to shift gears quickly with out missing :O
good luck achieving your target dude i plan to run similar times in the s13 once ive finished everything that i want to do to it (using a manual aswell not a auto)
if you just want to convert it to RWD, if its a R32, just pull the ATESSA fuse in the engine bay.
If its a R33/R34, you can drop the front drive shaft at the transfer case, this will make the car RWD too.
 Share
    • Hi i do buy a aftermarket headlight on ebay. For v35 skyline coupe. I know that its a plug and play and just use the old low beam light and balast from old headlight. But my problem is i dnt have knowlage on car and electrical thing. And the head light getnon ebay is the wire for halo ring light is not connected. I talk to the seller and he said that. What white and black wire for halo robg light is need to connect to RDL. Running day light. Anyone here can tell me how to connect it to Rdl? Which wire is yhe RDL?
    • Hey Kaz, Unfortunately I am not at home currently and wont be for a few more months so I do not have access to my files or CAD. And at this point I prefer to keep the files to myself as I want to potentially make a few more pairs and see if they will sell within the EU before openly marketing them. But the way it's shaped and how small it is, I don't think you can fit both an indicator and a fog light onto the same surround, unless they were very small LED-type clusters.
    • I’ve just installed a Uniclutch sport into my R32. I’ve been blown away by it… it drives like a stock Toyota Corolla. It doesn’t make sense to me that a performance clutch can drive this well. I was about to pull the trigger on a Nismo Coppermix twin plate when I discovered the Uniclutch and decided to give that a shot instead. They’ve changed the game and I couldn’t be happier.    I was previously using an Extreme cushioned button clutch with lightened flywheel. I’m still using the same lightened flywheel with the Uniclutch.
    • Mmmm no, that's a white series 2 R33 GTS-t
    • Oh and.... "no bubble on the dash" ---> immediate no mod status.
