  • Replies 105
dale - im using my vid cards capture prog lol the software only lets me do 1 channel :D
as for the tunes... its an MP3 disk with everything on it from montel to adam freeland and she has the remote while i concentrate on the rd :D
Nice vids inark :D
Will try to remember my camera next time.
My photos are here as really low-res poo-poo, but I have all the photos in nice swanky hi-res (they print nice sized on an A3) so let me know if you want any.
Low res gallery
2.4MB 640x480 archive
A3 prints:
why i love torturing her and she like going on the cruises... theres a part in the vid where all u can hear is screaming and the camera going everywhere cause she thinks she is going to die lol funny stuff... me saying "i hope the brakes dont fail" just adds to it hahaha
gordon - yeah i got some vid of that area but its all filled with the above and u can barely see anything.... shame... was flying around there
poyz - i was broke and wasnt going to go... she went out and brought a heap of meat, case of soft drink and lots of snacks she even filled my car up to get there and again to get back and to work this week so i doubt i'll be ditching her :D
Niceeeeeeeeeeeeeeeeee!
If only mine didnt get car sick...could have been the same...:P
Hey nark, was that your wheel arch trim?
Damn near hit the thing at 120:D
yeah, i could tell your gf was holding you back on the staights comin' back:)
overall the cruise wasn't too bad, just that I wasn't gonna drive too hard on the way up there, seein' as i've only had the car for a few weeks.
Still need to go on one of 'em advanced driving courses;)
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
