  • Replies 111
Posted Images
CLASSIC! I like your sense of humor.
Alrighty heres where I stand, ive managed to get this far:
Ive replaced the studs and at the stage of attaching the clover disk to the drive shaft. Everytime I push it in the shaft back slides back in. Im not to comfortable beating the crap out of it now. So im hoping to grab some advice of some people who have done this before.
Any advice would be good. Im about to cry as it has taken me a week to get this far.
LOL damn man sorry to hear bout that, that thing looks awesome.
BUT, the same thing happen to me and a friend on a go-kart, he was driving along and the wheel just flew off and i was chasing it.
would have been funny to see it happen to a car.
once again though, sorry! lol
At the time it wasn't so humerous but now i look back on it I see it as an omen and have a good chuckle over it.
I found a few things that definitely need looking into. At present it still has only 3 wheels but i have sourced a hub for $150 so I will get that fitted this week sometime.
Tomorrow I will order the custom carpet and roof lining which should be ready by the weekend. After that its a full service and tune then registration time.
After rego comes the paint touch up and she will be ready for show and tell.
How much is the custom carpet and roof lining. When u say carpet, it's not the floor mats right? It's the whole bottom end.
Cheers! =)
Full bottom homie.
Dunno how much its worth find out tomorrow when I meet the guy. I hear there is a guy in Cannington that is the shizzle for this. Hopefully he can whip up one in Calsonic Blue for me.
sorry to hijack, how much did it cost to send it from the eastern states. I am thinking about buying a skyline in melbourne. did the seller handle the arrangements to get it transported or did you do it from perth?
also i noticed ur car is quite low, any transport damage? the car i am thinking of getting has a bodykit.
Sup,
Hijack away. I went through Patricks Autocare and it cost me a little over 1400 to get it here. I went on word of mouth rather than what was the cheapest as i didn't want anything to happen to he car. If i had to do it again i would probably use someone else.
As for damage, from what I can see, there was none caused by the transport company. Just make sure you document eveything when it is recieved so when it gets here no yobbo has ganked your hard earned gauges/wheels/girlfriend.
As for the ride height, with the front bar fitted the car sits around 6cm from the ground. If you get one with a kit I would strongly advise having the front bumper taken off before transporting.
Edited by Tofu
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
