i have the following mods:
fmic, turbosmart dual stage boost controller, apexi s-afc 2, k and n pod filter.
before i got the safc2 installed i tried boosting it too 12-13 psi and i was getting this hiccup in the engine when i put my foot to the floor, and i thought it would have to be the a/f ratios, so i decided to get the safc 2 as the power fc was way out of my budget, for $900 i got the safc 2, had it installed and dynoed.
as it was being dynoed on high boost of just under 13 psi it was doing that hiccup thing again, and eventually the guy must have tuned them out cos it wasnt doing it anymore. so i was happy. took the car home and for a few days it was fine, but then it started doing the hiccup thing again, not as often as before but still there and very embarassing when wanting to drag sumone, the whole car would shudder for a second or 2, and keep going, it would literally jerk.
does anyone have any idea what this could be and how to fix it???
sumone said that the boost level was too high and was blowing out the spark in the plugs, so i bought new ones, ngk platinums and regapped them to 0.8 mm, but no improvement, the only way to avoid it is by using a maximum of 75% throttle.
any help would be appreciated...:D
https://www.sau.com.au/forums/topic/11897-boost-problem/
thanx for the replies.
the safc 2 takes care of the boost cut, could be fuel pump,
i did turn my boost down a bit, but no help, if i turn it down anymore there wont be any point boosting it
i think the best bet is to get it redynoed but i thought there might be a simpler solution
https://www.sau.com.au/forums/topic/11897-boost-problem/#findComment-211025
if this hiccup is around 5000rpm, then it is most likely the same spark problem that all the R33 owners get after boosting their cars.
Have a search in here for "misfire" or "5000rpm" and you'll see other peoples replies.
I think they were saying to gat the plugs to 0.7 (I think)
good luck.
https://www.sau.com.au/forums/topic/11897-boost-problem/#findComment-211380
Change your fuel filter, you should do this regularly anyhow.
The fuel pump issue, will play out like this;
* try getting up to 5000rpm in 1st using light throttle, then at 5000rpm cruise put your foot flat to the floor. If the same issue occurs straight away it's probably not your fuel pump. If it allows you to gun it through first and then starts doing its thing in 2nd or 3rd then the fuel pump might be at fault.
The spark plugs maybe too hot for the load. Try a range or two colder. Buy cheap copper ones.
Check your base timing.
https://www.sau.com.au/forums/topic/11897-boost-problem/#findComment-212547
ive just changed the fuel filter so its not that, it was doing it before and after the change.
i dont think it happens in 1st at all, but in 2nd and 3rd it does only when i put my foot to the floor on high boost.
i think the heat range for my plugs are a 6, could b 7, cant remember
https://www.sau.com.au/forums/topic/11897-boost-problem/#findComment-212559
My car is doing the exact same thing, I got new spark plugs put in today gapped .8mm. Its been on the dyno yesturday and today and turning the boost down from 1bar isn't helping. I have a standard ECU which will be replaced by a powerFC as soon as I get around to ordering one.
Yesturday I only managed 175.1hp on the dyno.
Tommorow I might have another go.
Mark
https://www.sau.com.au/forums/topic/11897-boost-problem/#findComment-212906
If it happens when you hit 2nd or 3rd from a standing start test and doesn't act up at all through 1st gear then the fuel pump is perhaps at fault.
When I say standing start or rolling start run at 5000rpm I mean going from 1st through all the gears to 4th as if racing. You might only get to 2nd when it occurs. If it occurs in the later gears and not the 1st fueling is the issue.
It could be ecu 'fuel cut' also.
https://www.sau.com.au/forums/topic/11897-boost-problem/#findComment-214337
i was told the safc 2 removed fuel cut?
becos i had a fuel cut defender in there before i got the safc 2 and when i got the safc 2 installed he said i dont need the fuel cut defender anymor
i'll take the car for a thrash and see if it does it in 1st or not...
i was actually driving it pretty hard yesterday on high boost and it didnt do it once, seems to do it when ever it feels like it
https://www.sau.com.au/forums/topic/11897-boost-problem/#findComment-214401
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
