  • Replies 44
Tomorrow night for those who care - I will be there, Im pretty sure that Jayce, Erica, Mark and Luke will be too mabye even Andrew and Leigh...
I tried a long time ago to strike up some interest with everyone (see S*E*X it aint trivial) but to no avail... So the new plan is - If you want to go then go - if you dont then dont (sit at home and drool like an idiot infront of that so called "TV show" the OC)... Anywho, its up to you!
P.s.... Only the coolest and most dedicated ACT SAU'ers kept going when everyone else bailed, heh heh heh ;)
Edited by Bullet32
https://www.sau.com.au/forums/topic/119029-jerra/page/2/#findComment-2389642
well my smart idea of taking the other means of transport netted me a nice cold that i am still trying to kick so i am out won't be able to make it till the 22nd so see you all then :D
SOFT! :)
Whats with the empty edited posts Beau??
Edited by Bullet32
https://www.sau.com.au/forums/topic/119029-jerra/page/2/#findComment-2392817
Idiot so the Jerra club in Jerra ... gets the street directory out I see I see so trivia night on tuesdays the place to be huh? hmmm might go for a drive tonight and see whats the go
JaiJai,
did you happen to make it out last night? cause at about 7:15pm, a grey R33 with an SAU sticker on the back window cruised through the carpark and left without saying hi. thought it might have been you? :D
https://www.sau.com.au/forums/topic/119029-jerra/page/2/#findComment-2431511
no the evils of work! I will go next tuesday ive got a white r33 with a torn and damaged front bar with a dodgy hybrid intercooler....qld plates
yeah thats what you get learning hot to drift
buuut I will make it out next tuesday Ive got nothing on so hopefully
I'll be able to meet a few of you!
https://www.sau.com.au/forums/topic/119029-jerra/page/2/#findComment-2432457
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
