  • Replies 59
is this 84-88 FM band here? or jap fm band? i just checked on my stereo and the lowest it will go is 76mhz... which +18mhz = 94mhz AUS!
if it is going to be 84-88 mhz AUS... i either have to replace my stereo for the night... get every1 to turn there's up LOUD... or miss out! :(
LOL :(
i have a jap stereo that won't pick up aus radio stations.
i put an 18mhz down-shifting freq.conv. into it so MMM for eg.(105.1) displays as 87.1 on the stereo!
the lowest the display on the stereo will go is 76mhz (japanese) which is 94mhz here in AUS.
I can't get any radio station that resides below 94Mhz on the FM band!
I was asking inark if the 88-84 was aus freq. in which case i can't read it! or whether he was teling me that it was 88-84 in JAP freq.?
does this make more sense?
Originally posted by phorj
is that 88-84 here in AUS though? so my JAP STEREO will read 70 (due to 18mhz shifter)?
the lowest Mhz it will go is 76mhz = 94mhz here in AUS?
great... NOW I'M CONFUSED!
lol
the station freq u will need at the drive ins is low 80s which ur radio should go to :)
so in other words.... dont stress :(
SH!T... i have no hair left!
i'm having a bad day... ask jet! he came round i wasn't exactly in my 'sunday-best' haven't sahved in 3 days... go uni assignments to do! AND CAN'T WORK OUT MY JAP STEREO!
*ok... breath now... that's a good boy... breath*
much better now that that's out!
thanks for the shoulder to cry on nark! :(
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
    • The fact that US/JDM plates actually fit the skyline bumpers properly is a big, big thing for me as they are the correct dimensions. Annoyingly you can't opt for a normal plate (or plate combination) in that size. You have to make up your own one, and at that point you'd still know it wasn't randomly assigned.
    • Well, really, that's any ECU, because it's not so much the ECU that the tuner connects to, but a laptop that's connected to the ECU. You have to have the tuning software installed locally. The "remote" part is essentially just remote desktop (RDP) or VNC type access. Nevertheless, if you're looking to upgrade, then you're immediately in the Haltech/Link territory, both of which can be done by any number of competent tuners here in Oz. But without a dyno, you'll definitely also need a wideband O2 sensor fitted, and you'll probably be relying on "auto" tuning a bit, where you drive it around under various loads and then apply the corrections that the ECU learns (basically applying the fuel trims that the ECU has to do to correct the mixtures). Tuning the timing is a little harder. It can be difficult to trust the old OEM knock sensors on RBs, so it is definitely best to have someone who knows what they're listening for, with knock ears (a piezo microphone connected to the engine, and and little amp and headphones so the listener can hear the angry men with hammers who live in the engine). That is more difficult to do remotely, and I suspect the only sane way is to be quite conservative on timing. But that's OK. You're probably waaaaay better off with conservative timing where you are. What is the fuel situation? 98RON available? Or low grade jungle juice?
    • I see your point, I didn't think too deep into it, was purely focused on the price. There's no bad blood between myself and GSM, they acknowledged the price was cheaper else where and at the time couldn't match it.
