i have an auto r32 gtst and this might sound like a stupid question but i havn't owned a turbo car before so be kind.
does the auto gtst still have a stock bov?
if yes i think mine does not have one as when i'm on boost and i take my foot off there is no noise like one would expect.
also, if yes then where is it located? on my intake piping before the throttle body and before the bend there is a small pipe which runs off the main pipe which leads to nothing and is blocked off...anyone know if this is where it should be...or does someone have a pic of a stock bov which i can compare to. maybe its there but stuck or something.
as i said i havn't owned a turbocharged car before so i am learning as i go...
thanks,
Waz
https://www.sau.com.au/forums/topic/11910-bov/
MM2death has given you the pic.
If your one isn't making any noise, then it is probably because you have the standard air box.
When you have a pod filter, it is very free flowing and you can hear all sorts of induction noises.
also, when the bov vents, you will hear a sshhhhh sort of sound.. different to the aftermarket psshhtt sound.
the standard bov makes more like a hissing sound.
IF your bov is removed and all holes are blocked off, and you put a pod filter on, when you back off from the accelerator, you will hear a fluttering sound.. like ch ch ch ch ch ch
Hope this helps.
And there are a fair few turbo cars (engines) that don't have bovs as standard..
here are a few.
Cordia turbo.
CA18DET engined cars.
VL Turbo
That's a few off the top of my head.
https://www.sau.com.au/forums/topic/11910-bov/#findComment-211395
Mate... if someone knows what that is i'll fall off my chair.
ALL Auto's i've seen... R31/R32 (imports we are talking here) and i'm assuming it's the same for a 33 but ain't seen and auto one yet.
They all have that little pipe thing your talking about and it goes nowhere and does nothing. (that i know of)
It's also the easiest way to tell if you car has had a manual conversion done to it at any stage :(
https://www.sau.com.au/forums/topic/11910-bov/#findComment-216550
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
