Blown away . Sorry but why would anyone want any cold start compensation at much over 45 - 50 deg coolant temp if that ? The last engine/ECU , and a MAP one at that , I tuned with reasonably crude AFR measuring devices needed none over 40 deg coolant temp . I don't see a problem with 68 deg thermostats other than getting a little heat into the lube oil and any decent synthetic oil will have a quite respectable cool pouring index anyway .
I am no tuning expert but getting the timing right was critical to how my engines behaved at no/light loads right across the coolant / inlet air temp ranges .
Turbo wise I REALLY hope we dont take on the American practise of calling compressors by their inducer (inlet) diameter ie TO4R wheel being "66 or 67" . Its really confusing because a small diametre big trim wheel can have a similar inducer size to a small trim large diametre wheel . The TO4R wheel is ~ 84mm 63 trim and 66. something mm inducer . If Garrett were to produce it (highly unlikely) it would be called GT3584R . It sort of fits between the GT3582R and the TO4Z (BB TO4R/P Trim) but built on the GT3582R's GT25BB centre section rather that the big shaft BB centre section from the TO4Z/GT4088R/T51R/GT4294/02R etc .
My rant for today , cheers A .
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
