18' Volk Racing and 17' AVS Model 6 wheel [ Post #1 ]
I have a 18 x 9 inch Volk Racing F zero Challenge suits R33 GTR and 17 x 9 inch AVS Model 6 suits R32 GTR (because R33 GTR has bigger brakes) both are white and very good condition. Asking for $3700 for Volks racing wheel and $2000 for AVS wheel.
The volk racing wheel is ultra light, a very nice wheel only i have to sell it to pay some bill.
pic up shortly
Thanks for that, Jimbo. It is indeed a very nice set of wheel, i think it is even lighter than many of 17 inch wheel. and yes it is the one with blue inner. If i got more money to pay off my car, i wouldn't want to sell it
  • 4 weeks later...
I am not sure yet whether the 18x9 would fit R33 GTS T yet, haven't really try it. because my car has GTR body panels so it fit GTR wheels. I will try with my friend's GTST, then I will tell you whether it fit or not
  • 3 weeks later...
  • 9 months later...
Originally posted by JiMb0
Once again, I'm running 18x9's .... on a gts-t ...... :confused:
Jimbo just because you've got 18x9's on your gts-t doesn't mean these will fit a gts-t
These mags would have GTR offset and your mags would have a offset to suit a gts-t which means more then likely these Volk's would stick outside the gaurds
guys... heh... we jumped from the 20th of the 8th 2002 through to the 30th of the 5th 2003.... i doubt he has the wheels or even checks these forums, seeing as his last post was from last august.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
