Hi guys,
I will be swapping my R32's cooked transfer case for a fresh one within the fortnight. I have not come across much information on SAU in relation to swapping the transfer case.
Can anyone who has done so offer any advice/tips on doing so?
Are there any parts that need to be replaced? eg washers, o-rings or anything alike?
From what I am aware of at present to get the gearbox out I have to remove and install the following:
1. Speedometer cable
2. Front propeller shaft
3. Clutch slave cylinder
4. Starter motor
5. Gear stick
6. Reverse lights plug
7. Exhaust (from the front pipe or from the dumps?)
8. E-TS hydraulic air bleeder actuator
9. Gearbox obviously
Removing the transfer case from the gearbox?
Edited by Remix-
  • 1 month later...
I don't have all the details but it was pretty straightforward once the box is out
The hardest part was the shifter, there is a rod from the transfer case where the shifter goes down to the gearbox it was fidly. The transfer case is just bolted on from memory, not sure if there was a gasket.
All the details would be in the workshop manual
Cheers for the response Duncan.
As I am attempting this in the driveway (backyard love :)) I would like to attempt to remove and replace the transfer case without taking the gearbox out (heavy bastard), eg I would prefer remove gearbox x-member/prop shaft and tailshaft to tilt the motor/box backwards towards the firewall thus giving me access to the top of the transfer case.
Has anyone attempted this with success?
I'm pretty sure you won't be able to do it, all the fiddly stuff is on top of the transfer case, even if you get your hand up there chances are you will drop the pin or rod into the box :P easier to take it off I reckon.
Would be interested to hear the trick if someone knows one :)
I've taken the transfer case off my busted gear box. Definately possible only with gearbox out of car.
Once you see the bolt and roll pins you have to remove in top of transfer case opening you will see what I mean. 1/2 hour job to pull apart with basic tools.
Box has to come down, no gasket, just use gearbox gasket goo. It's a good idea to change the selector shaft seal. Like others said its fairly straight forward when the box is on the ground. Pull the top cover off and knock the rollpin out enough so you can release the selector shaft.
Its a bitch to R+R the box off the car on the floor though much easier with a hoist and a tranny jack.
Drain the oil ouf of both before removing and dont forget to bleed the attessa.
You dont have to remove the dumps ( just as well they would be impossible to remove on the car), just the front pipes.
I just had my car up on the hoist and it appears my transmission fluid is leaking out of my transfer case somewhere. The mechanic couldn't pin point it exactly as obviously it sprays everywhere when driving but it appeared to be leaking out of where the front driveshaft connects and even possibly at a hydraulic hose at the rear of the transfer case.
Hopefully the box doesn't have to come out for this.
  • 4 months later...
Hey dude, just wondering if you know the part number for the selector shaft seal?
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
