f**k I HATE WEARING STOCKINGS! THEY'RE BULLSHIT!
And yes Bunta, they are nearly as bullshit as entrees!
entrees? As in food. I am sorry, they are not BS, they are more often than not tasty. Deep fried camembert cheese for example. You cant have it as a main meal, or even with one as its a bit odd. But as a quick something while your mains (say spare rips[how they are spare dont ask me]) is being cooked up, its just perfect.
Other dishes like say a skewer of garlic prawns at a bbq while the steak is cooking. Spot on.
Dont tell me Im wrong. Cause Im not.
If it is any kind of decent eatery, there would be no need for entrees
Entrees are an excuse to make the main small/ crap
Hence the reason they are Bullshit
Huh? You are not very good at debating are you.
Unless by decent you mean McDonalds, which is FAR from decent. They dont have entrees simply because they have no more menu space to fit them on, and well, they suck.
Any DECENT like REALLY decent eatery will have proper sized dishes. You simply need to eat more. I can chow down a entree and a main at anywhere DECENT. But two mains Im not going to do it. Well not going to do it to be able to fit in 2 bits of garlic toast, and 1/2L of cold rock after. Cause you gotta have cold rock.
Its also about the flavour. I never want just one meal, and one flavour for the night, or even lunch. I feel if Im paying good money I want some variety. Its that or a reef and beef or something, which is normally the cost of a mains and entree anyway.
That is because I am not debating...be sucked in by entrees I dont care
The fact that you can make a pig of your self impresses no one
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
