Dead fing set! Im going to start a cull of any dropkick that cant drive. You crash, BANG you are dead. Bloody traffic on the way home because a truck 'driver' and I use the term driver loosely! crashed his car carrier!
And I didnt swear! whoo!
A few of us are going to teh autosalon on the Goldie on Sunday and I'm viewing a property on Saturday...so woo hoo excitment there :)
Karen, send me an SMS when you get down the Coast as we are camping down there and I want to have a quick look at the Auto Salon before breaking camp and driving back to Brisvegas, washing the car and getting ready for the Monday Cruise!!
Ummm .... because of this
Don't tell me you are one of those bandwagon jumping Skyline n00bs who seem to be under the misapprehension that the Skyline marque started with the R32 and finished with the R34?
Oh and hopefully this when it comes out :)
No, you misunderstood. I own my car, not my Boss!!!!
Are we all on the same weekend here?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
