hey guys,
too lazy to create a new thread and scared of being flamed!
What is involved in puting a factory 33GTR bar onto a S1 GTS25T
do you need the guards? does everything else line up?
cheers,
Dan
Me too!!
Yeah i spent from 3pm til now doing them and i have had a few bourbens inbetween and they are the best pizzas i have ever made...
I made one garlic chive and cambert cheese pizza
Then i made another 3 with bacon, salami, shreaded ham, caps, mushrooms, olives, tomato based sauce, garlic chives, eshalots, egg, motzerrla cheese and chedder... WOW they took for ever to make...
I then put them on pizza stones and onto the BBQ for 20 minutes... They were awsome...
I even made the bases from scratch... Thats what took so long...
I should have taken a photo...
qld sucks ballsack
go blues
I aggree with your idea but would have used different words...
More aggressive words of course... :D
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
