what bike is that?
kawazaki...its got me seriously interested lol
anyhoo, after a great night because of the win, i'm now off to bed to ponder my next modifications :D
nite all
P.S very good of you to come visit us qld'ers after the gut wrenching lose mate, cya round :D
its a GIXXER kart which means its got a gsx-r motor in it from a motorbike, but its probably modded with those carbs on it.
live simpsons ..... http://ralph.ninemsn.com.au/img/videos/video079.jpg
Oh yeah that thing. I swear there was one just like it with a 1.3 worked to the black stump and back mini engine in it tho, must be different just thought it was that one as it came out of the back of a mini ute.
Hahah! Not a lot, in a great mood 1) the moroons won last nite and 2) the job I’ve been working on & staying back late at work got sent out last nite ;)
Watchu upta?
P.S AND I get tomorrow off, 33hrs worked up already this week before today hehe
noice, noice
I am pissed at 2 people at work. One is the temp who is now staying until FARKING CHRISTMAS! ARGH! I swear, I have never felt anger towards anyone as much as this woman. She just won't shut up! You think I'M annoying... holy shart! This chick is unbelievable. She sees a piece of paper on the carpet, she'll talk about it. She sees some dust on a plant, she'll talk about that too. Then she'll ask you about something, and TALK OVER YOU while you're answering her.
The other one is a lady I gave the mintues of a full day meeting to... over a month ago... and has just come to me and said "I have lost them - can you re-do them?" Then I discover that not only has she lost the hard copy... she has misplaced the file on the computer as well. ARGH!!lakjdfklj gkla t5io jglkjdkljakljklj ;):D
I did think about pushing her down the stairs... but that is going too far *sigh*
Now my little chinese friend that I talk to occassionally is asking me the price of fish and rice and flour... and I love him to bits but I am not in the mood for being a check-out-chick today...
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
