and anna, u should see my job, theres changes 24/7 lol, u get use to it though
*sigh* it's not changes that frustrate me... it's dickheads that can't make up their mind about minor things. Menial tasks that they like to do to make themselves look busy... when really it's ME doing the changes that they talk about. And I get lumped with all the 'creative' type stuff. Like banners and displays and gift tags and conference programs.
So while i'm doing it all to save their asses... they're having a good old time saying 'oh, just move that margin in a little bit, and take the bold off all the 'with thanks'. Sure... easy enough right... bear in mind i'm stuck using WORDPERFECT... my ass... WORDLESSTHANf**kINGPERFECT!!!
If you guys want pineapples...
Jump on the phone to Steve in the retail warehouse at fulcrum at moorooka head office.
Ph: +61 7 3892 9000
Fax: +61 7 3892 1526
Then ask him to hook you up for the model of car you have...
He said most skylines and supras use the $19 one. Worst case is that you need the $23 ones...
There are 4 pineapples in total to install to you suspension and they took me a little over 2 hours to fit all 4...
I have launchs like a GTR now... :)
Nah seriouslly i have heaps more movement in the rear end and now can get the power down to the ground. So now is a good time to hook up that new GT30 high mount ive been waiting to do... :action-smiley-069:
that's good that we can buy them seperately. We bought some for a friend, and one went 'missing', so she's stuck with 3... not much use for 3! So that's just solvered our issue. Spanks col!
How this for fun... just got car back from paint shop.... decided to go on the highway and bam.... a stone chip..... i cant win..
COL.... very said u didnt remember me....
oh il entertain you guys with some of my more memerable autobarn requests
like this guy that just came in with his falcon with a leaking waterpump...
he wanted to get some "glue" and block up the drain hole on it so i wouldnt leak any more : so he could drive it up to newcastle (2hrs away)
it never ceases to amase me some of the tings i get asked.
but he wouldnt listen so i sold him some "liquid steel" L:o
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
