Took the beasty to Willowbank last night and managed a best of 13.7 and then I gave up due to the long lines and the idiot who mistakenly thought his XD Falcon could be turned into a pretzel by torque alone!! I never thought that the 'U' bolts that hold the diff to the car could be shot through your fuel tank???
Was a good night though and I am very keen to go again and woop Col's ass, but he has bought a good turbo and other stuff and I will just have to take on Terry now and see how we go......
hmm sounded like a good night. Would have come out but think i would have run some lousy times..who else went??
Had to chuck in a new fuel pump, which STILL hasn't fixed my slight pinging as i come on boost :whistling: guess next step is a pfc at least its woohoo tax time.
Takin the car out to emerald sunday as i'm workin out there for the next 3 weeks. Thinking of fitting some of those roo scarer whistle things as i'm a bit worried of hitting something out there lol
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
