hmm i will just go down there and argue is... and try and hopefully talk sense.... if not... hmm learnt from ym mistakes..
i better show up there though.... if he writes me the ticket.. i should just say u should have bought a skyline, half the price,, twice as fast... you lost buddy, better luck next time.. (then ill get arressted or something lol)
supples y'all!?!?!?!?!??!?!
hey, watched 'jarhead' today... this got me thinking back to last year...
when the Iraqi war started last year, did anyone else consider flying over there, to earn some big $$$$'s, in security work?
or am i the only one?
Guess not... laaaa deee daaaaa!!!!
hrm... woke up at 5am this morning...
went to work... did 2 hours then the night shift guy called in sick... so they sent me home and told me to come back at 9:30 tonight....
am working through to 5am now....
didn't get any sleep this afternoon, as i wasn't tired....
so by the time i get home in the morning, i will have been awake for 24 hours....
w00t
hrm, i think this 2nd redbull is kicking in... i'm feeling all energetic now :P
still have another 2 in the fridge to keep me going if i need them! w00t w00t!!!! :D :D :D:sick:
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
