The lady in the seat next to me had the nerve to say to the hair dresser "You let Men in here"....
I turned to her and said "Oh darling you dont have to worry about me, Im Gay"...
It was really funny...
BTW... For those who dont know me, Im not Gay... Except that time with Bunta but that was for medical research...
that was meant to be a secret :blush:
Fark there is too many band wagons around this place!
At the start some one got a good tune from Matty Spry...then every one was on to him like fats kids on a birthday cake
Then I say I didnt choose him cause I heard some bad reports and now people are in a panic??
I chose Chiptorqe because people that I truseted suggested it...If Matt works for you why change that based on my personal opinion, and that didnt work out that well for me anyway!
And John why the hell do you need another tune...your car has been tuned more times than any car in the history of man kind
because recently the studs were replaced to which hardcore nicely told me one of the studs were missing when they took the manifold off. now that all studs are there (so hardcore have told me), it needs another tune from what dan explain to me the other day.
as well as the fact that the piece of shit is spiking. recently it's also been splattering alot for some unknown reason.
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
