they're about A robot who comes to life, came out late 1980s ... it was awesome when your 5, I bought them today from k-mart for 15 bucks. With classic lines such as "hey laser lips your mumma was a snow blower" .. cracked me up at 5 years old :)
not alot aye, just trying to fix my car today.....
hey daz,
i hear ya :) hey whats public transport like in buderim? could i say get a bus from maroochydore up to buderim hospital each day?? (workin up there next week) but worried about the car due to this :
http://www.skylinesaustralia.com/forums/in...howtopic=129882
started taking all the things off my car today to change the crossmember and steering rack over and i got to the support braces for the lower control arms, and i coueven budge the nuts on them so i used the rattle gun, but i stuffed the nut, roudned it on the edges a bit now. so i cant get it off.... it was my fault bcoz i was using the rattle gun at work, and i used a star socket on the rattle gun not a 6 sided one...... big mistake, and the worst part is i only have till 2moro to get it out of my work some how....... that is where i am doing it all at on my own.
http://www.riversandsapartments.com
on bradman av wherever that is lol
bradman ave is in maroochydore along the riverfront. u should be able to get a bus from there. the mains top is at the plaza. there is a huge bus terminal u can get a bus to anywhere from there.
really?? awesome! that might solve some probs. Still need to drive up there tho...
id say your hotel is towards the bli bli end of the bradman ave though, not the maroochydore end. u will be able to get a bus along there though, there is stops all along that road. u mite have to go to the plaza and change busses to buderim hospital, once u do it once it will be easy after that, but it takes a while to get anywhere by bus though,they go everywhere in between on the way to where u wanna go.....
Yeah i might just take my chances and limp it around on 5 cylinders. I'm working 12-8pm shifts all week, so maybe i can get a local mechanic in mooroochydore/buderim to have a look at it in the mornings,
Can you recommend a good mech??
well my mate owns his own mechanic shop, not far from where u are staying, its in depot st maroochydore.
Cox Kerry Motor Repairs
Cnr Service & Depot St Maroochydore QLD 4558
ph: (07) 5443 3507 Motor Engineers & Repairers
might give them a call tuesday...
gunna try a new 02 sensor i think. Nissan dealerships aren't open 2morro i think, i rang both autobarn and repco today they dont have any for r33's (i have a part no for the ngk replacement one but both stores said they dont stock ngk!?!?
I think supercheap does so i'll go see them 2morro. Or i'll grab a genuine one from nissan maroochydore (assuming there is one lol)
Try using Metrench sockets. I have a set and used them heaps of times on stuffed bolt/nut. They will still grip onto an almost round hex head.
Good luck
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
