i was going to go to the coast today for lunch... but nobody wants to go with me ;)
if old mate sump adapter isnt going to take 2 weeks to get, i'd come for some lunch jason!
chin up buddy, maybe its time to hit the bottle? haha drown then sorrows!
lol sounds like ur having a load of fun. if you lived closer id come round and give u a hand
well, my boss's didnt really care today about it but the other delivery driver was having a whinge about my car being where he loads his ute, so i told him i would have it moved as soon as i could. sop i got my engine mount today, and installed it then i had to get the mechanic form across the road to come and work on it and bolt it all back up for me, then we drove it over to his workshop and had a look on the hoist, the sump has a small hole in it, which we repaired with metal stuff that fix's it.
and now the newproblem is the tailshaft has a dent in it, so now i have to get a new one of them bcoz its all out of balance, i know u can get them resleaved, but i mite aswell get a second hand one in good condition if i can... so any1 got one laying round lol
why i just happen to have one lying up in the shed lol
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
