Share?
*hands you a cookie*
They are like my pirate pancakes :)
did you sample the raw cookie dough before cooking??
mmmm cookie dough ;)
Haha of course..
That stuff makes me feel sick tho..
It was my boy who bought the stuff anyways ate half of it.. then gave up.. lol.. told me i can use it to make cookies.. (sometimes i really think he is a woman) hehe
Hey Karen, can you PM me the club’s bank details so I can drop my membership renewal in and so I can get some more stickers too :)
CLICKY HERE for FAQ's...3rd question relates to the SAu Qld bank account ;)
No stickers at the moment...hopefully this week *sigh*
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
