kit came with everything, cooler, piping, all silicon connectors, bolts, clamps, :D
and t\he stepped in poop hahahahha
Hmm, all star just quoted me 590 bucks for an install.
I wont tell you my kit inc pipes, clamps and sil cost less than 450 then over a year ago... :D
Yeah labour is the big thing, if a shop cuts the time down and does a dodgy fit, then they are liable for the damage it can cause...
kit came with everything, cooler, piping, all silicon connectors, bolts, clamps, :P
590? woah! thats how much the intercooler and kit would of cost ya
$350 from wat milanco would charge.
see dan from on here as well. top work he does and highly recommended by many of us other skyliners from off here!
karen... a wannabe of noobs :D
This is the first i have heard about this...
Dont tar me with the same brush...
Can someone fill me in with whats going on around here via PM plz...
You should keep your beef with John, with John...
The rest of SAU dont really care...
I UNDERSTAND WERE YOU ARE COMING FROM... BUT YOU SHOULD BE TALKING WITH JOHN... HE THE ONE THAT HAS BEEN SAYING THAT SAU ARE SAYING THINGS ABOUT ME...
hmm i might jsut find someone off here who wants to make 100 bucks and a carton of piss :D
looks at col. i know you want coronas
If i had the time Bryn i would...
I only installed Pear's boost controller last Friday night after months of him asking...
Times money...
Also try a smash repair shop, they are mechanically minded enough to do an intercooler kit...
Try Enoggera Smash repair, their super dooper...
hmm i wont talk to dan, we had issues, as nice a bloke im sure he is, i will go else where. a mate of mine jsut said that, since you suppling all the parts, they charge more as they wanna make money off ya
I have not been talking with John???
I dont have a slightest clue what your talking about...?
Seriouslly I have no idea whats going on in here???
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
