hi
I have a s14.. .am i allowed in here
ofcourse!
You make a good point Anna bar one thing, sit dosn't just happen A$$holes cause it
indeed! So... are you the asshole that's gonna make the sale of our 33 possible? :wave::D
Ok well i have the Tea just need the chippies
i will fax you a chippie. what's your fax number?
nope
now on your way
:O welcome :wave:
Shhh! Ofcourse he's allowed!
Thats not very nice....But I hope so yes!!!!
07 4725 4511
If you give me you mobile number ill send you a pic of the Tea!
Edited by SLO-89
yes.
ed tells me not to mess with anna. ahahaah
Hooray for ed. He is a legend. But far to skinny. Twas good to see him again the other day!
07 4725 4511
ahahah me too! Okay sik! *goes to fax*
don't worry daniel, andrew will make up out of his dream soon enough :D
I hear alot of talking but not alot of driving??? I remember you were going to beat Dave aswell so I will make sure he comes along.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
