Ahahah I will! I was saying to andrew last night that she is, by far, the stupidest piece of dumbass shit i've ever met in all my life. We rofld. Not nearly as accurately as you though :O :O
And I don't argue with the driver.
f**kING SICK OF PEOPLE TODAY f**k f**k ASS SHIT f**k!
I am with you i have f@@king had enough of today i want to fcuking go home
HAWTLAND!
da na na na na na na na na na na na na na na na HAWTLAND!
named after me obviously
home time isn't far
haha actually it is for you guys! lol.
sif ny1'd wanna go there :O
awweee it's okay, i was only messin around :O
hahaha you have no idea how close you are to the truth! lol
ha ha damn stinky Dave
haha
how did dave get to qld so quickly? I only saw him last night!
ahahah awww poor dave. He had chilli last night. Chilli plays up on him. As does steak. And Twisties. And everything else he eats :O
Have a cup of tea
And sniff some glue
Have a cup of tea
And sniff some glue
Does the tea have rum in it???????????
That glues smells sh#thouse
i need a shoulder to cry on :O
what has happened dear?
No rum. Just rooibus tea!
And I know it smells shithouse. I was giving you an activity to partake in.
Yeah i know.
TODAY IS SO FARKING FARKED UP I FARKING HAD ENOUGH I AM SO GLAD TOMORROW IS MY LAST DAY HERE CAUSE THIS PLACE REALLY REALLY SHITS ME NOW
I kinda feel better now
meh, im over it now, couldnt give a shit when its ready now...im gonna buy some more parts for it, why not *sigh*
and all of this can be put down to one person's fault :O
I blame liz
yep that'll do!
Have a cup of tea
And sniff some glue
hahah u crack me up
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
