*takes leaf out of josh's book* but i am THE best ;)
the banter will continue until it is actually taken to the track, im sure... *waits for comment regarding when that'll be*
you can't be the best, coz I am ZE best!!!
oh and I love the banter, but only when the otherside understands that I'm going to kick their ass!
Cant go wrong if it flutters better then a VL turbo.
oh man it's so awesome!! lol
me and my mechanic were standing there for like 5mins revving it and then cracking up laughing!!! lol
li22eh I know you're teh best. You beat most guys and it's funny because then the excuse reel comes out ;)
woot for the big fat maid servent in gone with the wind. :huh:
lol.... I love that excuse reel, it's my best friend!!!
ohwell, in the end we all know the almighty GTR wil prevail ;)
ahahahaha noice
But no one ever seems to understand
Yeah you were using it on me before ;)
Well a 32 is supposed to be about 1440 or there abouts
Yeah it is supposed to be....But J boys is stripped has no aircon and it only weighs that much :huh:
yeah well you we being cocky about being faster than me.
I had to shut you up.
SIf I was being cocky! I listed all the reasons why in my post! And not one of the reasons was me being a better driver! *Goes to find the evidence*
93 Silvia Q :huh:
ok.. with an s14 adm engine, s15 brakes, shanef's gtr fuel pump, some gay intercooler.. and 3inch exhaust of course... the work has only just been completed.. got a few little problems to work out before I move onto suspension etc.
OMG!!! Another Silvia Driver!!! ;)
but sad to say i opted for the RB20 option, with heaps of other stuff... i cant wait to drive it its getting its full tune on the 4th dec.....
hahaha.. yeah you were!!!! You were before aswell.. but I bit my lip lol.
*fixes hair* heeeyyyy lol
you, slider and I can have silvia wars!!! apart from his has aids so don't go too close
sounds awesome!!!!
Bunta - make sure this dude comes out with us when I go up there next!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
