Yeah Shane the dyno day is a AllStar again, I finalise the details with Richard tomorrow afternoon... :)
Then I have to talk to the team (execs) and we will be under way with a 6 week window to get cars on the rollers...
*buys giggle gas*
I had to be a Harveys at 9:30 and i left there at about 12ish...
I had Noosa Maccas for breakfast and i went to the littl cafe over the road from that shopping centre for lunch... Was really nice, the coffee shop with all the dresses and gift ideas...
Gibbsons?
Damn eh the only day I dont come into noosa and do a few poser laps
Yeah Shane the dyno day is a AllStar again, I finalise the details with Richard tomorrow afternoon... :O
sweet man, the gtr should have its final tune by then aswell :D 370awkw here i come ;)
So yeah, keep Saturday the 20th of Jan free everyone...
Full details will be up hopefully tomorrow night...
will do
i'm off home...c u all at dinner tonite ;)
P.S we need 94 off 22overs :)
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
