swing me ur account details and i'll refund what u paid for it :glare:
thanks... but lets not jump to conclusions!!!
I'll get it tested to ensure it is the pump and not just a kink in the lines... but I'm pretty sure it's the pump.
Liz said she missed me :glare:
more likely you miss my wang
man it's hard to recognise you kids without sigs!!!
oh I got my car back this morning!!!!!! IT's awesome... f**kin ace.. until the fuel pump died in the ass lol
huh? :sick:
is it a pm??
dont worry i got it!!
ha ha ha :wave:
hahahaha
it's sooooooooooo quick! I haven't even opened her up yet, jut 30% throttle MAX and she blows me away!
You;re a chick... Or are you *suss*
oh wait, that's right
silly me.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
