I second that.
I 3rd that...chicks are generally nut cases and would geld you if you ever said anything wrong by a horse...guys on the other hand are different story...half are guy and half are champions like... Dual state champ **cough cough**
hey fellas get a load of this pic. I did a clutch in a mates car last nite, and this is what i found when i pulled the box out. That furry looking stuff was all inside the bellhousing, and its the actual organic clutch packs from the clutch face :laugh:
was pretty funny aye. also when i went to remove the top starter motor bolt (THE biggest pain when doing a clutch) to my amazement it wasnt even there! however when i removed the starter, this bolt fell down and it was the top one, just sitting there lol. i got told hardcore did the last clutch in the car, dodgy bastards. oh and also when i went to take the flywheel bolts off, the main crankshaft bolt was coming loose! so lose in fact u can turn it with ur fingers! lucky this guy's motor is still alive i say :laugh:
hardcore f**ked up plenty of shit on my car.
didnt even replace the broken gasket in my manifold and used corolla studs and less washers then they were suppose to when replacing the broken ones in my manifold.
glad they are out of business now otherwise they would have a handful to deal with from me!
According to the Alaska Department of Fish & Game, while both male & female reindeers grow antlers in the summer each year, male reindeers drop their antlers at the beginning of winter, usually late November to mid-December.
Female reindeers retain their antlers till after they give birth in the spring. Therefore, according to EVERY historical rendition depicting Santa's reindeers, EVERY single one of them, from Rudolph to Blitzen, had to be a girl.
We should've known... ONLY women would be able to drag a fat-ass man in a red velvet suit all around the world in one night & not get lost.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
