Hahaha, drinking adventures, i told you last time shane, I will not wear that mini skirt and serve u beer.
but seriously, sounds fun, :), Aphids R33 should be here, getting its transplant so u can help out :huh:
hmmmm doing an engine transplant whilst blind, this could be fun :P
P.S i wont be getting under the car, just incase 'something' goes wrong :P
hmmmm doing an engine transplant whilst blind, this could be fun :)
Like say.... I dunno, an rb25 gets missed placed in to a cefiro, and the R33 somehow just gets an RB20 in to it???
I dont think thats too wrong tho...
if u want a rb25 with a fcuked cylinder then go for it, :P besides, i think his ceffy will get it before urs lol
so no one wants to recommened a movie :huh:
OMG i just realised im going to this Tuesday night dinner :P. you will have to introduce yourself shane, so i know who will be rocking up on my door with a carton :)
so no one wants to recommened a movie :P
dont know any good movies mate.
will do mate, cant really miss me though, tall skinny bloke that likes to stir shit :huh:
P.S the carton will be for my drinking purposes only
will do mate, cant really miss me though, tall skinny bloke that likes to stir shit :P
hehehe i will strip/dance for booze :PBJ:
troy, i assume u've had braided lines made up for ur car. i need some turbo lines made up for my car and want to know a few things:
1) what size lines for oil feed (-6 or -8)
2) what size lines for water feed (-6 or -8)
new ones r like $50 from autobarn bryn
Yeah, but i always get roped in at that place, and walk away spending alot, and sometimes leaving without the item i went for lol
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
