hey guys, quick question. someone brought this to my attention lately, its off Boostlosing but still,
THORPE84 Yesterday, 12:00 PM Post #11
"what the hell is it with QLD and stolen skylines!!!!????
f**k man i hope you get it back, this shit happens far too often
edit, there is a thread on skylineaustralia.com on how to bypass your alarm system and people wonder why they get stolen?. you cant mention street racing or company names on the threads but you can tell someone how to steal your pride and joy wtf."
i dont know if its bulls*#t but it never hurts to ask. anyone know about this?
Hooray! Andrew's Christmas present just arrived. And seeing as he doesn't get online during the day anymore, I'm going to show y'all!
Yes, I know his turbo is not a garrett, but it was the nicest one I could find that would fit, and i'm going to unpick the word garrett and have someone professionally re-embroider apexi into it :(
i dont know, you've all been here longer than i have so i thought i'd ask. like i said, it could be a bunch of s**t but there's no harm in asking. just thought i'd confirm it thats all.
thanks
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
