lol ull see pal, its so good infact Zoom Auto Imports rang me and want in on the build :)
i think the trust built 6 speed dog box might have something to do with it
they say talk is cheap, suggest you post pics to silence your critics :sick:
lol ull see pal, its so good infact Zoom Auto Imports rang me and want in on the build :sick:
If you mean your gonna out a 2jz into a 33 it has been done...
there was one a APC but it was a 2j in a 180 the engin mounts broke while on the Dyno and there was a law suit of some sort....
Nothing new, of course zoom would want in cos think about all the cash they gonna make!!
now where's that S13 with da 13b in it......
IAN IS AN EMO!
IAN IS AN EMO!
IAN IS AN EMO!
IAN IS AN EMO!
IAN IS AN EMO!
IAN IS AN EMO!
IAN IS AN EMO!
IAN IS AN EMO!
IAN IS AN EMO!
IAN IS AN EMO!
IAN IS AN EMO!
IAN IS AN EMO!
IAN IS AN EMO!
IAN IS AN EMO!
IAN IS AN EMO!
IAN IS AN EMO!
lol APC are rat shit tho
when engine is in and mounted i will post pics...
trust me mate, its being done properly.. boilermaker is making my engine mounts
What Happend to your "fully Sic" $80000, 400Kw R33??
is it still on the Hoist?? Maybe its A Purple Unicorn!!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
