sadly i dont work in those sort of labs - i do blood tests and stuff :) not much fun flammable things in our labs unfortunatley..
there are still fun things to do, but i will prob get in a lot of trouble for mentioning them on this site, also could be classed as terrorism :P
hehehe.....im up for a carwash if u want
but..its raining! whats the point?
my xmas was on nice and quite.....i got a nice new watch
ohh what sort? the watch i want is one based on the mclaren mercedes slr or the james bond ones by tag heuer but they're like 3K too expensive :P
cant say i've dabbled too much in that...we used to mix salt peter (KNO3 -potassium nitrite) with sugar to make reallly good smoke bombs, including one that made a 20m high mushroom cloud and melted a 1ft hole in concerete lol...
our ultimate aim was the manhattan project - a 100kg mother of all smokebombs, but we ran out of funds halfway through so endded up splitting it up into smaller ones :)
lol i didnt even look outside.
na my watch was only 600 guess im too cheap to spend 3k on a watch
Hey guys, seeing as how it is raining and I can't play golf or tennis (except on the Wii)
I and some mates are going to the Pavillion at West End to have lunch and play pool. Around 12.30
Dave
our ultimate aim was the manhattan project - a 100kg mother of all smokebombs, but we ran out of funds halfway through so endded up splitting it up into smaller ones :D
not bad. i cant really say some of my favourite accomplishments, but they are big :) i'll leave it at this and say that we managed to burn a brick wall with a coke can and dent a tree with a d cell battery :P
Morning.
not for much longer
Dave
Hmm not far from work... if they do lunch there I might be able to convince one or two of the very few people working here this week to come along :P
Dave
meh to drivin all the way into the shitty (city) :P
on other topics dave do you have one of those wii's ? how are they? been thinking of getting one but wasn't sure how the controller would feel in real life.
lol, how much did u spend on a watch
i think at least $601 is a good amount :P
haha j/k.. you can get decent watches for even around $150 so a $600 one should be pretty good.
One i have at the moment is 5 years old and i paid $210 for it, saw it in the shops the other day- exactly the same model nothing changed for $250 go figure lol.
i'm in the market for a new one tho, will probably ebay up to $500 or so for something decent.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
