Woof, hey Stephanie, hows your night going so far?
ahhhm pretty slow, im having a quiet night in, its one of my most treasured day off's so far, just been chilling out around home
IS there any good events on this sat night? sat day?....sunday day?
The thing that raises intake temps and makes intercoolers less effective?
Ahhh, no, its the thing that means I dont have to wear my wetsuit down the beach in SUMMER!!! Which is just insane. I'll put up with a less effective intercooler for a nice warm day down the beach.
ahh it is fun trust me I am helping dan with a couple of engines whilst waiting for my parts to arrive (damm supplier is now out of the type of turbo i want grrrrrr). Only thing is remember oil goes everywhere and to have a steady supply of rags avalible :)
Predictable ending but funny nonetheless... :)
TRADITIONAL AUSTRALIAN FARMING:
* You have two sheep.
* You sell one and buy a ram.
* Your flock multiplies, and the economy grows. You buy out your neighbours.
* You sell the lot and retire on the income.
AN AUSTRALIAN CORPORATION: (Workchoices!)
* You sell one, and force the other to produce the wool of four sheep.
* You are surprised when the sheep drops dead.
FRENCH CORPORATION:
* You go on strike because you want three sheep.
JAPANESE CORPORATION:
* You redesign them so they are one-tenth the size of an ordinary sheep and produce 20 times the wool.
* You then create clever sheep cartoon images called Sheepkimon and market them worldwide.
GERMAN
CORPORATION:
* You reengineer them so they live for 100 years, eat once a month, and shear themselves.
A BRITISH CORPORATION:
* Both die from foot and mouth.
AN ITALIAN CORPORATION:
* You have two sheep, but you don't know where they are.
* You break for lunch.
A RUSSIAN CORPORATION:
* You count them and learn you have five sheep.
* You count them again and learn you have 42 sheep.
* You count them again and learn you have 12 sheep.
* You stop counting sheep and open another bottle of vodka.
A SWISS CORPORATION:
* You have 5,000 sheep, none of which belong to you.
* You charge others for storing them.
A CHINESE CORPORATION:
* You have 300 people shearing them.
* You claim full employment, high productivity, and arrest the newsman who reported the numbers.
A NEW ZEALAND CORPORATION:
* That one on the left is kinda cute...
Hmm.
Ive never seen the inside of a RB. Most intresting.
its a bitch to do, but at the same time i enjoy it
ahh it is fun trust me I am helping dan with a couple of engines whilst waiting for my parts to arrive (damm supplier is now out of the type of turbo i want grrrrrr). Only thing is remember oil goes everywhere and to have a steady supply of rags avalible :P
the only 'mess' i made was when i took the turbo coolant lines off & the coolant dripped a bit, other than that no leaks or mess anywhere (other than on my hands and clothes) :)
im still @ f**king work...
so over it... I have done... get this... since I got in here:
Closed off some jobs that had allready been completed.
Twideled thumbs.
Gone for drive to shops. Gotten frozen meals as steph wont let me eat fast food anymore. For the record, they are shit. I ate half of one. Thanks hun for looking out for my health.
Twideled thumbs.
Got excited when phone rang, only to find it was coworker checking the lines.
Twideled thumbs.
Gone to car, gotten PC. Played games for 2 hours.
Now Twideling thumbs again.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
