Woof, hey Stephanie, hows your night going so far?
ahhhm pretty slow, im having a quiet night in, its one of my most treasured day off's so far, just been chilling out around home
IS there any good events on this sat night? sat day?....sunday day?
The thing that raises intake temps and makes intercoolers less effective?
Ahhh, no, its the thing that means I dont have to wear my wetsuit down the beach in SUMMER!!! Which is just insane. I'll put up with a less effective intercooler for a nice warm day down the beach.
ahh it is fun trust me I am helping dan with a couple of engines whilst waiting for my parts to arrive (damm supplier is now out of the type of turbo i want grrrrrr). Only thing is remember oil goes everywhere and to have a steady supply of rags avalible :)
Predictable ending but funny nonetheless... :)
TRADITIONAL AUSTRALIAN FARMING:
* You have two sheep.
* You sell one and buy a ram.
* Your flock multiplies, and the economy grows. You buy out your neighbours.
* You sell the lot and retire on the income.
AN AUSTRALIAN CORPORATION: (Workchoices!)
* You sell one, and force the other to produce the wool of four sheep.
* You are surprised when the sheep drops dead.
FRENCH CORPORATION:
* You go on strike because you want three sheep.
JAPANESE CORPORATION:
* You redesign them so they are one-tenth the size of an ordinary sheep and produce 20 times the wool.
* You then create clever sheep cartoon images called Sheepkimon and market them worldwide.
GERMAN
CORPORATION:
* You reengineer them so they live for 100 years, eat once a month, and shear themselves.
A BRITISH CORPORATION:
* Both die from foot and mouth.
AN ITALIAN CORPORATION:
* You have two sheep, but you don't know where they are.
* You break for lunch.
A RUSSIAN CORPORATION:
* You count them and learn you have five sheep.
* You count them again and learn you have 42 sheep.
* You count them again and learn you have 12 sheep.
* You stop counting sheep and open another bottle of vodka.
A SWISS CORPORATION:
* You have 5,000 sheep, none of which belong to you.
* You charge others for storing them.
A CHINESE CORPORATION:
* You have 300 people shearing them.
* You claim full employment, high productivity, and arrest the newsman who reported the numbers.
A NEW ZEALAND CORPORATION:
* That one on the left is kinda cute...
Hmm.
Ive never seen the inside of a RB. Most intresting.
its a bitch to do, but at the same time i enjoy it
ahh it is fun trust me I am helping dan with a couple of engines whilst waiting for my parts to arrive (damm supplier is now out of the type of turbo i want grrrrrr). Only thing is remember oil goes everywhere and to have a steady supply of rags avalible :P
the only 'mess' i made was when i took the turbo coolant lines off & the coolant dripped a bit, other than that no leaks or mess anywhere (other than on my hands and clothes) :)
im still @ f**king work...
so over it... I have done... get this... since I got in here:
Closed off some jobs that had allready been completed.
Twideled thumbs.
Gone for drive to shops. Gotten frozen meals as steph wont let me eat fast food anymore. For the record, they are shit. I ate half of one. Thanks hun for looking out for my health.
Twideled thumbs.
Got excited when phone rang, only to find it was coworker checking the lines.
Twideled thumbs.
Gone to car, gotten PC. Played games for 2 hours.
Now Twideling thumbs again.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
