no idea I leave work at 5ish get home quickly change and haul butt to dans and work till late and then go home sleep and do it all over again the next day. I'm not complaining as I learn heaps and actually enjoy building something using my hands and eventually watching it turn over. Also with Dan around we can give each other crap and listen to the radio as well.
hows it all going troy almost finished or whats got to be done??? :laugh:
yeah not bad mikey I have hte water pump tonight will paint it tomorrow and fit along with some sensors and waiting on an oil pump and also the turbo but most of it is comming togehter well. I am getting a couple of things powdercoated black just so they are nice looking but will also handle being in an engine bay :laugh:
yeah not bad mikey I have hte water pump tonight will paint it tomorrow and fit along with some sensors and waiting on an oil pump and also the turbo but most of it is comming togehter well. I am getting a couple of things powdercoated black just so they are nice looking but will also handle being in an engine bay :)
cool money is in my way again :) lol seems every time I think I can get things rolling some thing pops up & takes the money lol :laugh:
steph what r u still doing online go be with your man
hmmm give me a license to drive then :laugh: thats right
nah he's coming over.....just at 6am after work (what a lovely man i have XOXOX) .....im just excited about seeing him, hence why im up late ....cant sleep!
ahh yes i know the feeling I am not living much past a noodle diet but hell i hope it is worth it. I still have to decide ecu and loom but have worked heaps of overtime which has helped a bit.
lol pfft what?.....attached?...married?
im sure you know stacks of single people....
either that or yo havent met like the 50% of single people out in the world (rough estimate of mine :laugh:)
yas were both very lucky, i appreaciate him everyday for being in my life hehe
ok getting all mushy in here
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
