yep got the IXUS60 - the sales guy tried to hit them up with the 65... but she stuck with the 60
HAHAHA Knew that they would... Cause that what i tell them to do... >_<
Just shows my training actually sinks into their heads...
As i said the best bit is its a camera that is international so its great for travelers and they will never have to ring you and ask you questions as its a simple on/off point/shoot...
Its old people friendlly and its the same model I got for my parents also...
Yeah and thats why it broke so easy...
But I did put 3m alloy plate reinforcing behind the bar, but it just ripped the pop rivets out and all...
Quite messy and just adds to the list of things that I have dmagaed while doing this build... >_<
yeah i am thinking of fitting a front mount but i wanna get the bar done before i do it, just looking into options atm. i really want to know who this bar is from or is it a custom job??
Other than that the cutting of the front bar is the longest process as i was very particular about getting it all even and cermetrical...
It also had to be cut with a mini grinder 4 inch wheel this way I could get perfect clean lines...
I put the front mount on first and then modified the bar after the cooler was on... So i could shave it perfectlly...
You need to be carefull when cutting the bar that you dont chip the paint...
yeah i dont wanna cut it though, i was thinking of getting it moulded once cut out kind of how erin used to have her bar on her 33. ( if u remember)
i agree with u daz, im hopefully getting my front mount installed soon, (still sitting in box in garage) and im getting paranoid about what the bars going to turn out like, i dont want to cut any of it >_<
Well you cant cut into the car so you have to cut into the bar...
yeah i will cut up the front bar but i want it to be neat still and front bar is in need of a paint anyway, si if i get it modifed then il just get it resprayed or, other option is get a bodykit with front bar to suit? i like a few of them, but how strong are the aftermarket fibreglass front bars and even though they might have a cut out for the frontmount to show, does it mean it will fit behind it?
I reckon stick to what you got now and just cut it...
Go and buy a 4 inch plastic cutting disc for youe angle grinder and make out the cuts with a ruler before cutting...
Its a long process to get it perfect i think we spent 3 hours on mine to get it right...
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
