A vampire bat came flapping in from the night covered in fresh blood and parked himself on the ceiling of the cave to get some sleep. Pretty soon all the other bats smelled the blood and began hassling him about where he got it.
He told them to piss off and let him get some sleep, but they persisted until he finally gave in.
"OK, follow me," he said and flew out of the cave with hundreds of bats behind him.
Down through a valley they went, across a river and into a forest of trees. Finally he slowed down and all the other bats excitedly milled around him. "Now, do you see that tree over there?" he asked.
"YES, YES, YES!!" the bats all screamed in a frenzy.
"Good!" said the first bat, "Because I f**king didn't!"
ive been whoring for hours, and yet not on top ten posters..... weird
hahahaha you'll never catch me. i've been officially named the QLD whore i think! SPAM!!!!
:whistling: nice
in order to be no.1 you have to be at one with the spam. you have to have absolutely nothing better to do, and not really do any work. it is a skill i pride myself on :whistling:
hi mike
hi troy :whistling:
mike uve got a long way to go to be no.1 whore in this here qld whoretown :cheers:
thats what karen and lee and i cant remember the others were saying?
edit: oh and hi shane :thumbsup: (you only get an edit hello :laugh:)
Edited by lilmike86
BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BOREDBORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED BORED
Edited by lilmike86
hi troy :)
edit: oh and hi shane :wave: (you only get an edit hello :P)
yup, im teh real whore of this whoretown :D
P.S hi mike, u only get a P.S hi :P
some entertainment would be good right now..........................*taps fingers on desk*..........................anyone?
*unzips fly* :huh:
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
