The night didnt go at all how I had planned it actually. Better luck next time then :no:
I felt kinda silly sitting in the hospital ward, but I got a good appreciation for what the staff have to put up with. Raving drunkn/high/tripping lunatics, violent maniacs who got the snot beaten out of them, impaitent old men, demented women, it was all there...... I was surprised they had no security on hand, a mostly female staff too.
Compared to me who was just coughing up blood n stuff (I felt fine, mind you) I felt a bit out of place.
haha i just spotted an error on that lame movie twister.
they are driving on a dirt road, heading into storm, sky all dark, it goes into the car view, and its lighter, and a blue car drives past other way AND ITS A SEALED ROAD, then bam, back to dirt road lol
what a sh1t movie
Royal brisbane I think...
The big one near the valley, next door to the royal womens and the BP/Hungry jacks, also near newmarket road however I cant remember the name of the big road its on... (unless that is newmarket road? Or does newmarket road come off Kelvin grove road and connect the two?)
Only reason I went to the hospital is because I rang that 13 HEALTH number - i was on hold for aprox 30 mins but they were quite helpful and informative.
I see your "bad cold" and raise it to "viral meningitis"
But I'm nearly all better now!! At least I am home.....
yeah heard u had a lil trip to the hospital dave! good to hear ur all better now though :no:
feking fek.
I cant get the car to get out of limp mode. I just completly took the intake appart and put it back together again...
so it wasn't the AFM???
mna have you reset the ecu???
dude call DAn!!!
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
