hey all finally my first post in here haha, always reading the posts though, so how is everyone?? well have had my 95 r33 for almost 2mths now and damn i love it lol has actually suprised me with fuel economy lately after putting some injector cleaner through it, is averaging 10-11L/100kms.
yeah I have to get my wreck diving and deep water one for that but yes the instructor reckoned it is awesome and you can get right inside and have a bit of a look.
hi mat 085 yeah as you have read my day has been great i am a bit tired but most of all eager to go again. I have a r33 as well but unsure what the fuel economy will be one the engine is back in it.
yeah i think im lucky its so good on fuel lol plus normal driving i dont usually rev higher than about 3000rpm but still has plenty of power up to there, am on full boost (9psi) at about 2000rpm in 2nd, 3rd and 4th. in 1st boosts too about 7psi, hits that at 2200rpm, full bost in 5th at 2500rpm. what is the cheapest ppl have got their timing belts changed ect?
depending on how he drives it that is even high HP cars will be ok off boost if tuned properly
10-11L/100 is farking good tho
I had a garage built, 490rwhp R32. HKS F-con, $25k+ motor ect ect, low boost I couldn’t better 250k per tank.
Modified cars suck
hmm just spent a bit over one and half hours, cleaning both upstaris bathrooms, and vacuuming carpet, :) now gotta do downstairs vac, and mop, and then another bathroom :)
I should of hired someone, and not left the cleaning to one night vbefore parents return home
i know who would have thought,
I just finihsed the stairs, and now im having a SAU SPAM BREATHER :O:D
God even with the air con on 20, it gets hot cleaning :O Thumbs up to mum for doing it everyweek
How wsas everyones day?
ON the side of the road, waiting for a new silicon seal thing for my intercooler :O I love being stranded on side of road, in full sun,
A mate of mine came out and put it all back together for me (im useless mechanic)
Sorry for ditching u guys, i really wanted to be there
How good are the mares fins as these are a set i am looking at or the aqualung fins?
I have a pair of mares. I can't remeber the model - simplar to Mares Quattro (I think)
I'll see if I can track them down... If I can find them you can try them out if you like.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
