GT4 is awesome! but i cant wait til they bring in dynamic crashes with actualy effects!
I would hope that this is an option in the game rather than a "new standard feature"
I would prefer they fix up the bugs rather than add more features. They already have a good product, make it better by fixing whats wrong with it.
I found an awesome bug in GT3 one day. First you set the races to be more than 2/3 laps whatever it is (I think I made it 10 or something). Go into arcade mode and race with 2 people. I used the Smokey Mountain track. Have one person take off while the other sits at the start line. Let the first person complete their first lap, and then let the second car take off...keep an eye on the split times and watch the scenery flash by. I also think the car handles better. If the second driver is good enough they can lap the first car :huh: then the timing returns to normal :unsure:
Doing the above I was able to pull some amazing lap times
Morning all. Football finished for this weekend now so I can re-join the human race!!
Am going to shower and make my way to Milton to Umart and pick up my new DVD-RW and Logitech Speakers!!
Anyone doing lunch at about 1pm??
dude... go to MSY at Morningside :huh:
wholesale pricing on computer equipment.
UMart buy their gear from MSY :unsure:
Hey :unsure:
I need a new radiator...suggestions? Anyone know where to get PWR cheap?
dont preditor motorsport do them cheap, i would take my car there for them but i would buy it from them.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
